Product Summary
If you liked the sizing of BrightON Lightning Modules, and you're looking for something even smaller for those micro lighting projects then you're definitely going to like the BrightON - Dario Micro Modules.
Think of all those extremely small, tight Reverse Channel & Standard Channel Letters where now the issue is no longer being able to make a letter small enough, the issue is now being able to find a LED module small enough to fit inside and still have enough room for mechanical fasteners & other components.  Problem Solved!
Product Info
  • 10 Year parts, 5 Year Labor
  • 6500K
  • IP67
  • 12V LED System
  • High-End High Brightness LED Modules for Channel Letters and Lighting
  • Constant Current Regulated LED Provides Stability Control Over Time For Longer Life, NOT Constant Voltage
  • .36 Watts Per Module
  • U.L. File E520387 FULLY Weatherproof IP67
  • 162˙ x 142 High Efficiency Uniformity Optics
  • 100 Modules per bag.  6.12 Module Per Foot Fully Stretched (16.33 Linear Feet)
  • Typical Depths 1.25" - 5"
BrightON - Dario Micro Spec Sheet
BrightON Dario Micro Spec Sheet.pdf
Please sign in to comment
You will be able to leave a comment after signing in
Sign In Now
